Old 04-28-2009, 02:23 AM
Only Toyota for me's Avatar
Only Toyota for me Only Toyota for me is offline
Last Online: 11-21-2009 03:00 AM
Only Toyota for me will become famous soon enough.
Default Re: 800 lbs tongue weight
Originally Posted by MarkM7208 View Post
Well I talked with Equalizer today about the issue, and they suggested that I lift up the L brackets one hole at a time and see if it helps out, or I can take apart the hole assembly and add another washer which both will result in the same effect. They told me that through the different dealerships have told them that actually setting them up per the instructions was not the case and it was better to increase the amount of height above the hitch in order to give the correct amount of lift. The spring bars are not the case according to them.
From what i remember, lifting the L brackets are a slight difference and the number of washers are a big difference in distribution. So if you need a lot of extra support, put another washer or two in. If minimal support is needed, then adjust the L brackets.
This is just from what i remember, years ago when i had a TT. Got a 5er now, so i don't need to mess with the bars.
