Old 04-29-2009, 06:48 AM
SE2000's Avatar
SE2000 SE2000 is offline
Last Online: Yesterday 10:57 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
Default Re: Not a Tundra topper installed LB
I was thinking, that did you see if you could trim the front of the topper at the bottom and slide it forward? Maybe you body shop could cut the fiberglass and reglass it to fit better. since the tundra cab leans forward you would only be doing the bottom and it would blend bettr
