  #53 (permalink)
Old 05-01-2009, 10:22 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: DIY: Camry 2.2L 2001 VSV for EGR Replacement
Originally Posted by mosnar85 View Post
Great post!Thanks! I was able to change it out in no time! Although the problem is still showing up! I've changed the EGR valve, and the VSV, checked the modulator...i think its still ok,the filters were a little dirty though, cleaned them the best i could. Does anyone have any ideas. Maybe a plugged hose or something? Please if you have any info, i would greatly appreciate the input.
Make sure the vacuum lines to the EGR MODULATOR are not plugged or dirty and clean the throttlebody where they attach and then replace the modulator, they always (99%) are bad.
There is also a MAP sensor that reads the engine data and may be improperly reading, make sure the vacuum line to it is clean an the filter it attaches to is allowing enough vacuum thru.
25 yrs with TOYOTA
