Originally Posted by PS-RagE
I believe the Reverse Indicator line Tox is using is something he found in the kick panel. I made all my connections to the plug in the roof.
The voltage regulator is rather basic electronics - essentially "in", "out" and "ground". The details of the entire camera installation are here on my webpage: House of RagE - Road RagE II
You can also save yourself some misery and try to locate a 7807 voltage regulator. That will save you having to mess around with resistors
DOH! I already soldered my voltage regulator 3 days ago. I just tested it tonight so I guess I'm gonna try using it. However, its quite long so I might stop by Radio Shack to look for the 7807 Voltage regulator. Do I still need to pin it out?
