Thread: brake lights
Old 05-05-2009, 10:08 PM
timsalive timsalive is offline
Last Online: 05-09-2009 10:44 AM
timsalive is on a distinguished road.
timsalive's Photo Albums
Default brake lights
I have a 2004 sienna le that I have had so many problems with and have been told in no uncertain terms no luck from the dealer. One right now is that the brake lights are out. It happened before and I replaced the low profile 10a fuse. Now it happened again and the fuse was bad and replaced it but no luck. I wonder if it could be the pedal switch? Side note. I do have a towing harness but have had it for 4 years no problems. I only tow once a year. Also a fun one is the transmission wont shift unless you push the safety switch at the handle. Now it gets weird in that I turn on the running lights and the transmission will shift out of park like normal. Toyota says this is impossible. I tell them it is possible because it is what is happening. By the way power door cable broke, a/c went out 3 times and dealer wrecked van at dealership and tried to deny it. They finally fixed the dent and paint. Can I tell you how sour I feel? I have owned Toyotas since 1982.
Any ideas on the brake lights. Bulbs are good, I beleive they are on the side mount correct?
Thanks for any info
Tim
