Old 05-07-2009, 03:17 AM
Superfish Superfish is offline
Last Online: 05-07-2009 03:17 AM
Superfish is on a distinguished road.
Superfish's Photo Albums
Default Re: Underdrive pulley
Valve bodies are fully modified and calibrated to provide quick, positive shifts
High Energy Friction Clutches Installed in all Locations
Modified Pressure Control Electronics Installed
Lock up system is revised to improve converter clutch application, clamping force and torque holding capacity.
Lube system is redesigned to prevent geartrain failure and to increase lube flow
Pump is modified to provide increased pressure and volume
Planetaries and mating sun and ring gears are cryogenically treated
Splines are heat treated to prevent stripping
Thats what it says on there website the issue with programming is I havent found a way to program the tundras transmission the only programming the unichip does is to the fuel map.
