Thread: Question Help w/ equal-i-zer setup
Old 05-08-2009, 03:11 PM
jdubh's Avatar
jdubh jdubh is offline
Last Online: Today 02:21 PM
jdubh will become famous soon enough.
jdubh's Photo Albums
Default Re: Help w/ equal-i-zer setup
Originally Posted by JLinder View Post
I have a 08 DC 4x4 and a Jayco 27BH. I'm trying to get my hitch set right, and moving the L brackets down 1 hole does nothing, and the next hole up I'm worried might be to much. I weighed the truck w/ trailer, these are the weights:
Loaded w/bars on
FA 3300#
RA 3300#
Both Axles 6700# (don't ask me why it's different)
Loaded w/no bars
3100#
3700#
Both Axles 6800#
For what it's worth the trailer weighs 5150# on the axles w/ full fresh water but none of our stuff.
Am I transferring more weight than I should be, or does that look about right?
Forget the L brackets, put them at the starting position that the manual suggests. Throw in 8 washers on the stop that goes against the hitch. That made the biggest difference for me. Weigh your axles without the trailer to use as a starting point. Then when you put the bars on you should see an almost equal amount of weight go to each axle. So if your hitch is 600lbs then 300 should go to each. I have set it up before and put more weight on the front axles than the back...you want it even. If you put a piece of tape above your wheels you can measure the drop in inches and it should be equal.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
