Old 05-09-2009, 11:11 PM
*JIM*'s Avatar
*JIM* *JIM* is offline
Last Online: 02-11-2010 07:10 PM
*JIM* may have some regrets.
*JIM*'s Photo Albums
Default Re: Brake Pedal goes very low
(pbukowski) My first question to you is...did you buy OEM or aftermarket pads? I've seen aftermarket pads who's lining is a little lower than OEM giving you a soft pedal. If they are OEM, did you have the drums turned? I've also seen some drums that develope a ridge on the inside so that the new linings don't meet flush with the drum also giving you a soft pedal. (Highwaylizard) the popping noise's you hear have a 50/50 chance of going away for an out of round drum by having them turned. If they are too outta round, then new drums should solve your problem.
