Old 05-11-2009, 06:00 PM
ASE_Master-Tech ASE_Master-Tech is offline
Last Online: 05-11-2009 06:00 PM
ASE_Master-Tech is on a distinguished road.
ASE_Master-Tech's Photo Albums
Default Re: What to watch out for, and mileage
Originally Posted by thunder_pkg View Post
You should also get used to the fact that the climate control system was designed for a single cab, and is woefully inadequate on the doubles.
This is most apparent if you have four people in the truck in winter (for instance, going to the rink). The climate control system is completely overwhelmed by any moisture in the cab.
Expect icing on the inside of the windows and lingering high humidity if there is any snow tracked into the cab.
The climate control system is weak, weak, weak.
On modern vehicles, moisture accumulation in the wintertime is controlled by periodically running the A/C system in conjunction with the heat/defroster, this is the reason the A/C compressor comes on in the "defrost mode".
If there is a problem with your A/C (or you disconnect it in the winter), you will definitely have a problem with condensation..
