Old 05-12-2009, 09:56 AM
John224 John224 is offline
Last Online: 05-12-2009 10:06 AM
John224 is on a distinguished road.
John224's Photo Albums
Default Re: ES 350 2007 vs 2008
Model Year: 2007
Make: Lexus
Model: ES 350
Style: Sedan
Base Price: $33,000 estimated
Price as Tested: $39,000 estimated
Drive Type: Front-wheel drive
Transmission Type: Six-speed automatic
Engine Type: DOHC V6
Displacement (cc / cu-in): 3456cc (211 cu-in)
Valvetrain: double overhead camshaft
Compression Ratio: 10.8
Horsepower (hp @ rpm): 272 hp @ 6,200 rpm
Torque (lb-ft @ rpm): 254 lb-ft @ 4,700 rpm
Brake Type (front): Four wheel discs
Brake Type (rear): disc
Steering System: Power assisted rack and pinion
Suspension Type (front): MacPherson struts
Suspension Type (rear): Struts w/two lateral links and one trailing link
Tire Size (front): 215/55R-17
Tire Size (rear): 215/55R-17
Tire Brand: Michelin
Tire Model: Energy MXV4 S8
Tire Type: all season
Wheel Size: 17 X 7
Wheel Material (front/rear): alloy
Manufacturer Curb Weight (lb): 3,580
Recommended Fuel: Premium
Fuel Tank Capacity (gal): 18.5
EPA Fuel Economy (mpg): 21 City 30 Highway
edmunds Observed (mpg): NA
Model Year: 2008
Standard Engine 3.5L V6
Standard Transmission 6 Speed Automatic
Cylinders 6
Horsepower @RPM 272@6200
Fuel Economy Cty/Hwy 19 / 27
Combined Fuel Economy 22
EPA Class Mid-Size
Number of Valves 24
Torque @RPM N/A
Fuel Type System Gas Engine / Sequential Electronic Fuel Injected, Sequential Port Fuel Injected Sequential, Multi-Port Fuel Injected
Turbo (Yes/No) No
Overdrive Transmission Yes
Battery Output N/A
Compression 10.8:1
Displacement 3441 / 210
Bore X Stroke 3.70x3.27
Cruising Range 407 miles
Final Drive Gear Ratio Opt N/A
Power to Weight Ratio 13.2
Final Drive Ratio No
Valves Configuration Dual Overhead Cam / Twin Overhead Cam
Supercharged No
Electric HorsePower RPM N/A
Electric Torque Feet Per Pound N/A (foot-lbs)
Electric Torque RPM N/A
Electric HorsePower BHP N/A
Buy Low Price Ford F-550 Super Duty Wheel Hub Assembly, Clutch Kit, Brake Rotor, headlights, Brake Caliper, shock Absorber, Door Mirror, Strut Assembly, Alternator, Exhaust Manifold at theautopartsshop.com
Ford F-550 Super Duty Shock Absorber
Ford F-550 Super Duty Radiator
Ford F-550 Super Duty Door Mirror
Ford F-550 Super Duty Headlights
Ford F-550 Super Duty Steering Tie Rod End
Ford F-550 Super Duty Wheels/Rims
