Originally Posted by czechm8
A lot fewer connections from the previous AVN series.
When I pull my 5495 out I will do a side by side pic.
From what I remember there is about the same # of wires coming out of these connectors. I'll find out tomorrow though
I called eclipse today and the antenna cable and the 13 pin cable for the sat/hd radio connections are the same and you don't "have" to change them if you don't want to. All the other connectors are different. They are smaller from what I remember.
That grey plug is for the back up camera instead of the blue plug with the Y/R/W RCA jacks for the camera everything is a straight plug in on this unit.
There is no speed wire only reverse and parking wires on this. I found that to be a little odd, but I guess it's reading it from the GPS instead of the vehicle which makes more sense.
I'll post up some more pics and info tomorrow after I swap out the old for the new.
One or two odd things really, the instruction manual(s) 3 to be exact for the 5495 are now replaced with (1) and a fold out poster of instructions and quick start guide. Nowhere in any paperwork does it discuss the SD card and map updates. This is to come, I guess???
Scratch that, found the novel that this thing should have...
http://www.eclipse-web.com/us/downlo...df/726ae99.pdf
