Old 05-18-2009, 03:45 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Charcoal cannister replacement
The canister on a solara is in the rear above the rear crossmember, you DO NOT have to remove the gas tank to replace it, but you have to lower the rear crossmember and the muffler.
With p0440 and p0446 I would start with the CCV valve as described in the TSB I have attached, then maybe the canister or ORVR, that would depend on a smoke test and /or evap pressure test.
I would need your VIN to see if this TSB applies to your vehicle.
25 yrs with TOYOTA
