Old 05-20-2009, 10:00 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: groaning noise issue 99 Camry
Kinda sounds like the left front wheel bearing.
When you turn right, as you said your unloading the r/f wheel bearing, but your loading the left front and causing it to run in a different capacity under load. We generally have to use electronic ears anymore, as our human ears play tricks on us when it comes to deciding front/rear/left/right.
Had a Tundra a few days ago with a popping sound in the left front, turn out to be loose rear leaf spring "U" bolts. I had to lay under the vehicle while someone drove it fwd and bkwd to find it.
25 yrs with TOYOTA
