Old 05-20-2009, 11:23 AM
SAM-RAI's Avatar
SAM-RAI SAM-RAI is offline
Last Online: 11-12-2009 12:30 PM
SAM-RAI is on a distinguished road.
SAM-RAI's Photo Albums
Default Re: groaning noise issue 99 Camry
Originally Posted by 02whitetundra View Post
My wife's 99 Camry has 98000 miles on it. I have been having trouble with what seems to be a groaning noise up front. The noise happens with speeds above 40 mph and continues to get louder the faster the car goes.
I have switched tires from front to back and that has not fixed the problem. I also replaced the right front wheel bearing thinking that could be the issue. The reason I thought it was the bearing was that while taking weight off the right side (turning right), the noise would go away.
Any ideas? It's been a great car but I'm puzzled as to what the groaning sound is. It's not a metal to metal contact sound.
The groaning noise is probably from your worned out tire(s). Especially low quality/cost of the tires used. I have this same problem with my 04 Camry when I tried to save a few dollars by going with lesser tires. I fixed it with the new and better tires. How many miles are on those tires? But more importantly, check for tires wear to make sure it wear evenly or the noise will appear again.
" If At First You Don't Succeed, Try And Try Again. "
