Re: Double Cab folding seats Mod
If you look closely, there are three black metal tabs with bolts. The metal tab is screwed into the wood and the tabs are then bolted (screwed) into place like the picture. Do Not... screw the wood straight thru to the back sheet metal as it is only a single layer of sheet metal and you will have holes coming out the back of your cab.
Oh, I used really short sheet metal screws to hold everything in place. Its been a while and everything is real tight.
