Originally Posted by 1jeep
Toyo open country AT 275/65 18 E rated and they are much firmer than the previous C rated tires i had.
What pressure did you have when towing? Any E rated tire should be more stable than P unless you went with some mud tires then the blocks would cause an issue.
My first post has all the air pressures loaded and unloaded. I noticed that you have the 8' box. Maybe that makes a difference also. If I ran your pressure when unloaded, I would still float everywhere on the highway. 40psi all around seems to staybilize things when unloaded.
