Re: 2007 Prius jumps out of gear
Replace the shifter assy. We have had several of them do this, I have one in the shop as I type this to you. PM me if you need a price on the shifter. I will need the VIN
It is warrantied for 3yr/36K miles, or MOST ext warran should cover this, but you'll have to read the fine print about what is/is not covered.
Each to change yourself too.
25 yrs with TOYOTA
