Re: Project traction
The cases have the same dimensions, things from one case should fit the other. There are bound to be many internal parts differences, and I doubt you could buy just the Torsen and throw it in there. Input shaft, output shaft, shift forks... what is the same and what is different? I have a feeling by the time you get done it may well be cheaper to buy a whole case. Also do note that Toyota added a large amount of cooling fins to the 200 case. Running that front drive chain constantly creates significant heat.
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
