Originally Posted by 4.0flash
I assume the highlander is an inline set up similar to a pick-up therefore they probably used the pick-up trans? Since as you say, they did come with a MZ series aluminum engine then my next question is were all highlanders 4WD or were they also available in 2WD? Were they available with 6 speeds or 5 spds?
Highlander is FWD and the engine sits sideways just like a sienna and camry/solara/Rav.
No they are not all 4wd's, yes 2wd is available
No they do not offer a manual trans for a highlander
2002 Solara 1MZ-FE had a 5 speed manual as an option.
25 yrs with TOYOTA
