Originally Posted by hvw
The power door locks in my '03 camry do not work on the passengers side and the rear doors. (The rear doors don't have a unlock switch). The only one working is the drivers door and the only door it will operate is the drivers door. I've about driven myself crazy trying to trace the problem down. I've looked at a service manual but the problem is I don't know where the relays, etc are. Can someone please give me some direction. This is the first problem I've had with this car after 158000 miles. Thanks
What happens when you use the *key* to lock/unlock all doors?.If by "relays" you mean the devices that operate the door locks, my guess, they in the doors. the schematic does not show any external relays.BTW the schematic shows a 25A fuse in the engine compartment fuse box(Door1), I doubt this is your problem since it's probably for all doors and your drvr door works, but worth taking a look at.What do you mean by (The rear doors don't have a unlock switch)?.HTHJerryR
