Re: '03 power door locks
The rear doors are opened or closed by the two front doors. They don't don't have their own switch. Sometimes the power lock works and sometimes, most often, it doesn't. If they're working, using a key on the passenger side will open all four doors. Drivers side will not do that. It only opens that one door. I took the door panel off the passenger side to check the wiring, etc and I saw the "door motor". It looks expensive. I also looked at the service manual but cannot locate the switch it speaks of checking. It's a ten pin plug. Thanks for your help Jerry.
