Old 06-08-2009, 08:42 AM
JerryR JerryR is offline
Last Online: 11-23-2009 09:48 AM
JerryR is on a distinguished road.
JerryR's Photo Albums
Default Re: '03 power door locks
Originally Posted by hvw View Post
The rear doors are opened or closed by the two front doors. They don't don't have their own switch. Sometimes the power lock works and sometimes, most often, it doesn't. If they're working, using a key on the passenger side will open all four doors. Drivers side will not do that. It only opens that one door. I took the door panel off the passenger side to check the wiring, etc and I saw the "door motor". It looks expensive. I also looked at the service manual but cannot locate the switch it speaks of checking. It's a ten pin plug. Thanks for your help Jerry.
As far as I can tell (It's hard to tell from the diagram) the 10 pin conn are in the doors.BTW you do remember that to open all doors with the key from the driver door requires that you twist the key in the lock twice in quick succesion.being the problem is intermittent, I kind of doubt that you have 3 bad door motors.my guess will be eiter a loose ground or a broken wire between the door and where it goes into the body(there is a lot of flexing there).HTHJerryR
