Old 06-10-2009, 07:29 PM
Only Toyota for me's Avatar
Only Toyota for me Only Toyota for me is offline
Last Online: 11-21-2009 03:00 AM
Only Toyota for me will become famous soon enough.
Default Re: New LT Yokahama HTS for the 5er
Originally Posted by Blaque View Post
My trailer when loaded is approx 8500lbs. gawr for each axle is 5080lbs. I have those mission 225/75/15 tires and you guessed it, made in china.
Go get it weighed so you know how much ACTUAL trailer axle weight you have, then you'll know what tire you'll need.
If it's a 5er, you'll have about 6800 lbs on both axles but if it's a TT then you'll have more. Of course you really should weigh it loaded for camping so you can get a worse case scenario.
If you have any more axle weight than 6800, i'd be upgrading to 16" wheels and going that route. The LT, C rated tire i have is only rated for 1985 lbs per tire, so you'd want a little more tire if you're over.
If i had only 3 tires, it would max my tires out on capacity with 5900 axle weight. But i have 4, and i think i'll be good. You see, you don't figure in the pin weight as it's riding on the truck tires.
