Originally Posted by luciana
Hi all,
I am a new member in desperate help for advice.
My 2000 Toyota Echo has the check engine light on. My car performance is great, no difference in driving. I have no AC.
I got the following codes:
P0440-Evap Control System
P0441-Evap Control System Improper Purge Flow
P0446-Evap Control System Vent Control
Can anyone help?
THanks so much
Luciana
Loose or bad gas cap or hose off at aircleaner@vsv or
a cracked ORVR. The ORVR is located in the top of the fuel tank (see attchment).
The attachment is a picture of a camry, but they are the same idea.
25 yrs with TOYOTA
