Old 06-11-2009, 06:02 PM
Erich_121's Avatar
Erich_121 Erich_121 is offline
Last Online: 10-28-2009 04:35 PM
Erich_121 is on a distinguished road.
Erich_121's Photo Albums
Default Re: Whats the best way to hook up a cd player?
It's funny you ask that question. I have the same truck as you and just installed my pioneer. You don't have to run 4 pair of wires to the speakers, but you do have to run them to the old amp location. The B+, ACC, Illum. and ground are all found at one of the radio harnesses. btw, The AC and DC are wired differently, they have different harnesses. All the speaker outputs are located at the 12 pin connector that hooks to the amp. When you remove the old radio, at larger 20 pin connector on the radio, pin 1 is the constant battery. The ACC is pin 11. (for some reason my acc would not work, i had to grab a switched from the thermostat controls) The illumination is pin 2. Ground is pin 20 or frame. Next run 4 pair of wires for each channel to the old amp location. (if you have tweeters in the door they are already wired in parallel with the door speakers.) Then splice the correct wires together. (RL+ is pin 2, RL- pin 7); (RR+ is pin 3, RR- is pin 8); (FL+ is pin 4, FL- is pin 11); (FR+ is pin 5, FR- is pin 12.) The harness have pin numbers on it.
