Originally Posted by irahs
Thanks Mustang 67408:
The dealer told me just now that the code is 440. They couldn't do the test they need to do because the fuel in the gas tank needs to be less than 1/2 full. He suggested that I drive around and wait for my tank which is 3/4 full to get below 1/2 and then bring it back. He said it's safe to drive with it this way. He cleared the check engine light and tell him if it comes back on....
I value your opinion... What do you think???
Thanks again...
He is mistaken, the test can beperformed between 1/4 and 3/4 full as per the toyota directions. (see attachment)
A P0440 is a VAPOR LEAK, that means fuel vapor...........
I wouldnt if it were me.
The ORVR is APPROX. $250 total to replace
25 yrs with TOYOTA
