Originally Posted by duanels
Hi all
Not sure about programming the PTR7 so I was wondering if it could be hooked up to a 12 V battery outside of the truck and see if I can program it that way before I tear things apart in the truck just in case I can't figure it out.having trouble where it says feature at 9 10 and 12 need an option selected. Am I choosing delay on equals 1 or delay off equals 2?
Thanks
Yes you can power the unit up on any 12V source (extra battery, battery charger, etc.) I prefer this method to test things out.
You want to use option 12 and follow the directions. You need to program this time to hold the output to the VCS switch for 3 to 5 seconds should be good (5 seems the best). Set the delays as 2 no delay(blue), 2 no delay(white) and 2 no delay (orange) and for the outputs you can put 1 second (blue), 1 second(white) and 3-5 seconds(orange) and seconds from 3-5 should work fine but each truck maybe a little different. Hope that helps some, that way you get a 3-5 second timer on the orange wire (-12v) the other 2 outputs (blue and white) don't mater cause your not going to use them but it is easier to program them as 1 second just to make it a easy follow the program sequence.
