Originally Posted by WT
Yes you can power the unit up on any 12V source (extra battery, battery charger, etc.) I prefer this method to test things out.
You want to use option 12 and follow the directions. You need to program this time to hold the output to the VCS switch for 3 or 4 seconds should be good. Set the delays as 1 second (blue), 3 or 4 seconds (white) and 1 second (orange). Hope that helps some, that way u get a 3 second timer on the white wire the other 2 don't mater cause your not going to use them but it is easier to program them as 1 second just to make it a easy flowing to program it.
OK if I programmed it right when I put power it the ptr7 the red light on it should stay on for 4 sec.
