  #40 (permalink)
Old 06-16-2009, 09:47 PM
WT's Avatar
WT WT is offline
Last Online: Yesterday 10:30 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: VSC bypass mod on my "07"
Originally Posted by atvraptorman View Post
That is completely different then you said at the beginning of this post. Your drawing said no delay with the output at 5 seconds. Which one is it? Please clear up?
Okay sorry my bad I had to go review my drawing and TR-7 manual again its been a while since I worked on this particular project, so forgive my mis-typing. I corrected the post above with the correct information.
By adding the 1 seconds delay would not cause any issues and for the timer output time of anywere from 3-5 should work fine to since its basicly anything over 3 seconds should disable the VSC. I would say for simplicity keep it at no delays and 5 seconds as I stated in the orginal drawing.
Originally Posted by duanels View Post
OK if I programmed it right when I put power it the ptr7 the red light on it should stay on for 4 sec.
Okay if you program it right you should see the program LED light for the 5 seconds or what ever amount of timer you have it set for on the outputs. In this case we use the Orange wire as the output -12V to trick the VSC into thinking were holding the switch in for the 5 seconds.
So what you do to test it is to power the unit up by the red and black wire to the 12V source then trigger it by put the green wire to the positive 12V source too and then the LED will go on for 5 seconds then turn off. Or you can just tie the red and green wires together and apply 12V to them and the black wire and the LED will light for the 5 seconds and then go out.
Hope that this is a little clearer, sorry if anything I said earlier that may have been confusing but you got to give the old man a break since I have not worked on this in a while myself and don't keep the instruction in front of me all the time.
Guess if you really run into a problem programming the TR-7 unit you can PM me. You can send me the unit to program and test for you and I get it back to you just another option if you get really frustrated with getting it programmed up.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
