  #46 (permalink)
Old 06-17-2009, 06:47 PM
WT's Avatar
WT WT is online now
Last Online: Today 01:23 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: VSC bypass mod on my "07"
Originally Posted by atvraptorman View Post
I know you have to program all three wires for delay but do you have to do the same for output? Also when putting in a delay after you pulse once and it conferms it what do you do? Pulse it once for every second? Is it just like doing the timers for the output?
Yes you will want to fill them in to make it easy flowing when your programming it. So yes do the same for the delays and output timers
Originally Posted by duanels View Post
I pulsed brown wire 12 times for Feature Number
2 pulse for blue option=delayed off
2 pulse for white option=delayed off
2 pulse for orange option=delayed off
1 pulse for blue timer (seconds in ones place)
5 pulse for white timer (seconds in ones place)
1 pulse for orange timer (seconds in ones place)
Used the Flowchart on page 4 of instructions
Hope this helps
+2 this hits it on the head exactly except set the white timer as 1 and orange as 5 or if you want to be consistant do
5 pulse for blue timer (seconds in ones place)
5 pulse for orange timer (seconds in ones place)
Since you only wiring up the orange wire thats the only one thats needs to be set for the 5 seconds but it makes it easier for you to follow just program all the outputs to 5 seconds.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
Last edited by WT; 08-13-2009 at 05:53 AM. Reason: missed the white and orange timer set wrong
