  #48 (permalink)
Old 06-18-2009, 06:26 PM
WT's Avatar
WT WT is offline
Last Online: Yesterday 11:12 PM
WT will become famous soon enough. WT will become famous soon enough. WT will become famous soon enough. WT will become famous soon enough. WT will become famous soon enough. WT will become famous soon enough. WT will become famous soon enough.
WT's Photo Albums
Default Re: VSC bypass mod on my "07"
Originally Posted by atvraptorman View Post
I thought the orange wire was the one to set at 5 second output?
You are correct but you can also use the white wire since it too has a -12V output rated the same as the Orange so either one works if you want to make it easier you could program all the outoputs to be 5 seconds it would just depend on which one you wired to the VSC switch, well just not the blue since that would send the wrong voltage to the VSC and could either pop a fuse or casue some errors codes for sure.
You got to remember these TR-7 modules are not made to be used for a particular use they are very programable for your needs. You could use these to autofold your mirrors when the truck cuts off, I use it also as a pulse counter in my auto open tailgate project and I also use them to auto open/close my BMW's convertible top from the keyfob. only your imagination is the limit here.
So if your following my diagram you would want to set the orange for 5 seconds instead of the 1 as shown in above post. Sorry I missed that last night while I was reading things quickly.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
