Old 06-19-2009, 10:58 PM
tomhole tomhole is offline
Moderator
Last Online: 11-21-2009 07:07 AM
tomhole's Photo Albums
Default re: Towing Newb - Dave's learning to tow blog
Hard to tell from the pics, but you need to look at the clearance of the cam hitting the weight distribution bar in a turn. It looks like you have 5 links under tension, which is the minimum. But that looks like the cam will hit the bar in a turn. I would hook it up and check that out. If it hits, the cam will break. Simple fix is to tilt the head down more and put more links under tension. Same weight distribution, just drops the bars down more so the cam doesn't hit.
If it's just the angle of the photo, then no worries.
Tom
