CEL P0333 Knock Sensor Bank 2- HELP
Hi,
CEL came on and code read P0333 Knock Sensor Bank 2. Tightened Gas cap, however noticed that I am now running at a higher RPM than normal, 3000 @ 65mph (normal is 2100 @ 65mph). Dealer wants $500 + to replace sensor. Could the engine go into "safe mode"- retard timing due to a loose cap? How do you clear the codes (i.e. remove negative battery wire)? Any help/advice would be greatly appreciated.
Thanks,
Joey
2005 DC 4x4 Tundra
