Thread: What fuse?
Old 06-24-2009, 03:16 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: What fuse?
The luggage compartment light is tied into the dome light circuit. If the dome light works, then you do not have a fuse out.
What your describing is the plastic cover for the trunk light and you removed the BULB.
KOITO 12V3WK", means it a a 12volt bulb providing 3 watts of light.
Match up the bulb you removed with another new one and re-install it, you should be ok. If it still doesnt work, then you have a wiring issue as long as the dome light works.
25 yrs with TOYOTA
