Re: what HID's do you recommend?
Sorry I didn't do any write-ups while I was working on these. The project took me alot longer then my other retrofits. I was in no rush to get these done and with work and everything else, I just did spend an hour here and there. The most time comsuming thing was triming the reflector for the solenoid, and both shrouds - that took long. All of my other retrofits I did last year took me 1-2 months and working during the winter was fairly quick.
The projectors in there are LS460 Bi-Xenons (Asian Version-had a tough time getting)running DL50's "Fatboys" and S2K single xenons running DL50's "Slim Version". It is really bright as hell and light up the road with razor sharp cut-offs. From a distant you can see the prizms of color (blue,violet,purple,some yellow,and white). At 100 ft (depending on angle) you'll see blue and pure whiteness and as you get to areond 25-30 ft (also depending on the angle) you'll see more of the flicker effects of each projectors independently -like two gemstones glittering differently. Both sets of projectors without colormod just stock. I did swap the fresnel lens for a clear on the LS460's. Right now I'm working on the foglights and putting a projector in there as well. If you need some ideas, let me know.
