Old 06-27-2009, 08:39 PM
Frankenstein's Avatar
Frankenstein Frankenstein is offline
Last Online: 03-12-2010 09:41 AM
Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all. Frankenstein is a name known to all.
Frankenstein's Photo Albums
Default Re: Tow Mirrors - right upper mirror not convex
I appreciate the OP's point.
When the right side mirror is totally flat, you miss the wider field of view, and your head has to be in the same position to see what's happening along the right side of the truck and then you have to move your head forward to see a bit more to the side.
I'm happier having a pair of decent quality strap-ons (don't say ANYTHING Flash).
That way I get the inner mirror that gives a wide field of view, and a flat mirror stuck out further to see along and behind the trailer.
[Frankenstein's Monster]
Proud Member CBTMA
Radiant Red
