  #26 (permalink)
Old 06-28-2009, 01:39 AM
Johnnny Rock's Avatar
Johnnny Rock Johnnny Rock is offline
Last Online: 09-22-2009 05:08 AM
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock Johnnny Rock's Photo Albums
Default Re: weak air conditioning
Originally Posted by PagalDesi4Life View Post
Is the freon leak visible?
No Freon is not visible but where ever the freon is leaking out a little bit of oil always comes out with it and that you can see. You can follow all your A/C lines and look where ever two lines join together and look and feel for a small amount of oil on the A/C lines. Because your A/C works great on cooler days that tells me that you still have most of your Freon in your system and your Freon leak is very small and might be hard to find. You are probably only about a pound low on Freon. If you can't find the leak by looking at all your A/C lines I would not be surprised. They make a can of "dye" that you can put in your system the same way you would put freon in your car or truck. After you put the can of dye in you can take a black light and find the leak a lot easier. But honestly all this looking for a leak is NOT WORTH it to me. I would not bother at all because the leak has to be so small. This happened to me on a few past cars and trucks of mine and after adding the small amount of Freon that I needed I got another 3 to 5 years out of it before I needed to add another pound. So, In my opinion I would just add the small amount of Freon you need, not bother looking for the leak at all because it's so small and I would just deal with putting in a pound or two of freon ever 3 to 5 years. Johnnnnny
2004 Ford Lightning (Sonic Blue)
2003 Cobra with LOTS of work : ) (BLACK)
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
