06-30-2009, 11:46 AM
Re: Shake when Towing
It might not be the alignment. I imagine you've looked at the trailer wheel bearings. Might not be bad enough to be noticeable without weight but loaded, that shake can transfer to the towing vehicle. How much does your rear end drop with the weight on? Can you move the car a bit back on the trailer if you have too much tongue weight?
[Tundra Bay]
Proud Member CBTMA
Radiant Red
