Old 06-30-2009, 12:21 PM
TundraBay's Avatar
TundraBay TundraBay is offline
Last Online: Today 08:00 AM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Default Re: Shake when Towing
Moving the car back might do the trick. Also whatever you are loading in the bed of your truck should be toward the front to keep some weight on the front axle.
You could do some weight checks, is there a DOT scale near where you live? Are you allowed to check your weights on them? I weighed my rig here, it's very useful information, axle by axle and hooked up vs. unhooked.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
