  #99 (permalink)
Old 06-30-2009, 07:10 PM
Raiderfan0 Raiderfan0 is offline
Last Online: 07-29-2009 07:52 AM
Raiderfan0 is on a distinguished road.
Raiderfan0's Photo Albums
Default Re: Starter / Replacement Contacts
[QUOTE=tamu_tundra;270963]Need some help...
V8-2wd 2001 Tundra 84k-miles... and have what I believe is a starter problem. Symptoms are solenoid clicking with each turned key and then finally a startup after 4-5 tries. I've checked the battery and have cleaned all battery terminals.
I've searched through all the other threads, and it looks like most people have narrowed this down to the starter contacts. I want to go to the dealer and ask for these contacts, but I don't really know what I should be asking for. Is it the contact internally between the solenoid and the starter? In other words, would I need to take apart the starter and replace these contacts? If so, how many are there?
Or is it the battery contact on the outside of the starter? It seems that if the solenoid is clicking then this contact would be okay? I'm just guessing...
Also, from reading the other threads it seems you have to take off the air intake manifold. I'm assuming this is just the air-filter and surrounding box? Or it is a lot more involved than this?
Any help is much appreciated. I'm getting tired of playing starter-roulette every morning before going to work...
I had the same problem and cured it by changing out the "Starter Relay", it is located behind the battery in the Fuse and Relay box, price is approximately $28.00, much cheaper and easier than the starter, I hope this helps you.]
