Old 07-01-2009, 03:31 AM
diablito1975 diablito1975 is offline
Last Online: Today 05:44 AM
diablito1975 is on a distinguished road.
diablito1975's Photo Albums
Default Re: 2005 v8 Tundra - Coded key?
Originally Posted by SuperRunner View Post
Does the 2005 Tundra V8 use a coded key? I am doing an engine conversion with a 2005 motor and I purchased a seperate 2005 tundra ECU, but I cannot get the throttle body to work, or the injectors to inject fuel(starts up with starter fluid).
Thanks
did you get the ecu from same donor truck? could it be that the ecu you got comes from a truck that did have the imobilizer system. what part number is on the ecu?
something similar happened to me, i had the right ecu but the wrong harness under the dash, engine would only crank but there was no spark, so i run a wire from the starter relay to the battery, it would stay on but as soon as i changed gears it would shut off. thats how the imobilizer works, the right harness fiex my problem.
