Thread: Retrax
  #20 (permalink)
Old 07-01-2009, 11:25 AM
pistolpete's Avatar
pistolpete pistolpete is offline
Last Online: Today 03:26 PM
pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all. pistolpete is a name known to all.
pistolpete's Photo Albums
Default Re: Retrax
Originally Posted by WRXRacer111 View Post
What I did and what I think the Retrax instructions suggest, is drilling holes in the oval-shaped plastic plugs at the front of the bed. Route the drain tubes through there. I just used a utility knife to cut an "X" through the plastic plug and routed the drain tube through that. That way you're not drilling any metal etc. and it's pretty easy. Worse comes to worse, you can order new plug or, pop them out and spray them with spray-on bedliner to seal them.
or you could drill a hole in the plastic plug the same size as the tubing so as to try and remain as water tight as possible....better yet...I've found the supplied tubes to be too small to let debris (leaves, seeds, pods, bits of mulch) pass thru...one winter I had a huge block of ice in the canister because the tubes were blocked and water didn't drain before it froze....thus I came up with the following mod which increases the tube size, prevents clogging, secures the tube and prevents it from getting knocked loose by sheets of plywood or anything else you throw back there, and makes the fitting attached to the canister water tight (supplied material is simply a compression fitting with a rubber grommet that doesn't stay in place when trying to attach the tube)....
you can check out my Retrax modification in my photo gallery HERE
Pistol Pete
#1 COLTS fan!!!!
2004 Toyota Tundra Double Cab 4X4 (7844A), Phantom Grey Pearl, All weather guard package, fog lamps,keyless entry, 17" AA wheels, towing package, color-keyed overfenders, 4.1mm Limited Slip Diffy, Delux 3-in-1 JBL stereo, privacy glass, floor mats with sill protectors, bed extender
MODS- Line-X, Retrax, Onki nerf boards (part #328078), Wade vent visors (part #88401) , TracRac (rail # OL-21609), Ultimate Fly Fishing Rod transporter, Spin Caster Rod holder in bed, Recon bedlights fully adjustable w/"nightvision", HitchSafe, Weathertech floor liners (part #46030-1&2, grey), debadged, visors destickered, rear window stop disabled, dynolock/PL8500 power tailgate lock, tailgate protector mod with detachable floormat, Stebel Nautilus Compact Truck Air horn (300Hz), quick fist flashlight holder (all in photo gallery).....more custom suprises on the way!!
New members from the MidAtlantic (PA,OH,WV,VA,MD,DE,NY,NJ,DC) don't forget to check into the MidAtlantic Forum and introduce yourself!!!
