Old 07-02-2009, 12:47 PM
Greenie's Avatar
Greenie Greenie is offline
Last Online: Today 11:58 AM
Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything. Greenie has done just about everything.
Greenie's Photo Albums
Default Re: 2002 Tundra Can you diagnose? Bringing to Dealership
Originally Posted by lleroux5 View Post
Did the truck vibrate and shake at the low rps like mine does? I am getting that at startup, idealing, stopping/ accelerating after a stop. When I give it gas it accelerates past the vibrating and seems to run fine.
I do have less than a quarter tank of gas left and the gas has been in my tank for about a month.
I'm wondering if I should fill the tank, put in some fuel system cleaner and run it for a while.
I hate to pay a dealer for an easy fix......or will they consider it an easy fix. Sometimes easy things are hard to diagnose.
You may have diagnosed your own problem.
It's not good to let a vehicle sit with an almost empty gas tank for extended periods (a week or more). I never let mine get much below half a tank. Condensation can occur in a nearly empty gas tank adding moisture to your fuel mix. Additionally if you have bought fuel contaminated with water or debris then the fuel pump is going to pick up this concentrated contamination from the bottom of the tank. Try topping off the tank with a brand name premium grade fuel (not raceway or some other generic) and add a bottle of gas dry. I prefer Seafoam for this purpose. Also you might check your air inlet tube into the air box just in case Chip and Dale might have set up housekeeping in there.
Then take about a twenty mile loop including some freeway and see if this helps. You're going to have to buy gas anyway.
You did not mention if you had cleaned your throttle body. There are plenty of threads on this subject too.
More's Law: If more's good then too much is just right.
CBTMA member
