Old 07-02-2009, 03:40 PM
nytrousboy's Avatar
nytrousboy nytrousboy is offline
Last Online: 11-18-2009 06:12 PM
nytrousboy will become famous soon enough.
nytrousboy's Photo Albums
Default Re: Cat Delete Test Pipes
Weather your State does Emissions testing or not it is 100% Illegal to remove your catalytic converter per the Federal Government (EPA/ARB) Clean air act 1990.
The catalytic converter plays a major role in the emissions reduction of a motor vehicle. The vehicle manufacturer has matched a specific catalytic converter to the vehicle to minimize emissions output. Both CARB and the EPA do not allow the replacement of a catalytic converter with non-exempt "high flow" performance replacement unit. In fact, it is technically not legal to even replace a converter unless it has been proven by technician to have failed, and then it can only be replaced with an exempt OEM equivalent unit. (However, enforcement of this requirement is difficult and is the primary loop-hole that allows the usage of so-called "high flow" catalytic converters. Many of these units are sold with the disclaimer as being a "race" component and are not intended for street use.) Due to the hundreds of vehicle models produced over the years, it is virtually impossible to determine by glancing under a car whether the converter is the original unit, a legal OEM replacement, or a non-legal aftermarket "high flow" performance unit.
now will you get caught? that all depends, the EPA does have mobile enforcement and some law enforcement will check for equipment.
2004 Tundra stepside.
6" RCD lift, Camburg UCA, 4:56 front & rear, arb air locker, arb Sahara bar with 12000 bulldog winch, custom exhaust, 315/75r/16 km2 mt's
stubbs sliders, ARE shell, ORS Hub kit.
