Originally Posted by hofkamp83
to me if you want something to work with the horn 4wheelparts.com has a cheap electric horn system that will work for you, but you if you to go the true air horn way you can just go to a big truck stop and buy a compressor, tank and horn that are on semi trucks for a couple hundred bucks.
but if your your the type of person to go big or go home and want the entire couple block radius to here you then i would go for the true train horn which would be cool and would be the route i would go, that is just me though.
i have done the semi truck horns for work and are really simple but don't know the price or brand, i would be afraid about the ebay ones, i would go to a semi truck shop and ask those guys for there preference
Andrew
I had the same problem and looked at FIAMM and Hella, but ended up with a stebel combination. I have the Stebel TM-80 Magnum (x2), OEM (x2), and air horn all going at the same time. Here's a pic of the install - more in my album....
