  #18 (permalink)
Old 07-04-2009, 06:28 AM
GORILLA GORILLA is offline
Last Online: 11-17-2009 03:30 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
Default Re: Temp difference w/Aluminum Rads
hi, i have a 05, with a additive that dropped the temp 2 to 4 degree's. i live as you can see in south florida and i run my a/c all the time. and my antifreeze run's at 184 to 186.
so i don't reallly know if a alum. rad. will help, unless it is double the size or just larger. that would do the trick.
or put in a lower thermastat, where is will open alot easy'er.
the more air you allow to the rad, will keep it cooler, that is why i changed my grill.
i'm sure there are many other way's to lower the temp. to.
but i belive 184 with the a/c on in 90+ outside heat with the engine running is about the best it could be for me, especially playing like i do.
gorilla
