Old 07-04-2009, 04:37 PM
73mach1429's Avatar
73mach1429 73mach1429 is offline
Last Online: Yesterday 09:45 PM
73mach1429 is on a distinguished road.
73mach1429's Photo Albums
Default Re: 2005 Camry - Help with A/C Leak!
Be careful with a coat hanger so as not to damage the evaporator core. If you pull back the carpet, on the passenger side. You can access the rubber drain hose and clean it that way. You can also just blow a little compressed air up through the a/c drain hose and dislodge the debris that way. When the debris is dislodged, quite a bit of water comes out.
