  #16 (permalink)
Old 07-04-2009, 05:49 PM
lotust's Avatar
lotust lotust is offline
Last Online: 11-11-2009 09:01 PM
lotust is on a distinguished road.
lotust's Photo Albums
Default Re: Built myself a custom box today (pics)
Originally Posted by thumbster View Post
That's very clean work!
If you're bridging the amp into a 4 ohm load, you'll get the 2 Ohms per channel power output, but being the brand of amp it is, you're probably right about the enthusiastic power rating. I wouldn't go with anything less than 400 watts RMS on that woofer.
One way to roughly tell the power output potential of an amplifier is to look at the power fuse rating - if your amp really is a 300W amp (which I highly doubt), the fuse rating should be a minimum of 40 amps (12 volts x 40 amps = 480 watts times 60% efficiency typical for a class AB output circuit = 300 watts)
good info. Is there any way to run a 2 channel amp at 2 ohms with a single voice coil sub?
Incab LEDS all around,35w 5000k HIDs
Curt 2" Front hitch,JBA SS single Cat back.. sounds nice
N-Fabs
