07-06-2009, 09:43 AM
KE7WLF Master of Disaster
Re: '04 Tundra low mileage and timing belt
Originally Posted by Jack McDermott
Certain of you tend to suggest ignoring the timing belt situation, but YOU will not be responsible to pay for the other fellow's new engine if his timing belt breaks. Thinshavings, the fellow who posed the initial question, has an interference engine and, if/when the timing belt breaks, it will destroy the valves in his engine and require a rebuild. Toyota has invested hundreds of millions of dollars in engine and vehicle design. They really KNOW what they're doing and they build superb vehicles for us. To NOT follow Toyota's maintenance recommendations, after you have invested thousands of dollars in a Toyota vehicle, would seem to me a foolish bet. You will have nobody else to blame if you ignore Toyota's maintenance recommendations and your vehicle fails. Incidentally, I have absolutely no connection with Toyota or any Toyota dealer, I'm just trying to make good sense here.
Very well put.
25 yrs with TOYOTA
