Re: Portable Generators
I have a Kipor, it's a Honda Knockoff, made in China. Had it about 3 years now, electric start, auto-throttle. You will need 3K to start the AC unless you do some rewiring on your AC and change out the compressor then you can get by with one of those lil 2K models. Bad thing is that it weighs 130lbs. Good thing is that it's quiet as a Yamaha or Honda but much much cheaper. Got mine new for around $1200. I leave it in the back of my truck when I run it at rest stops to run the AC, looking to mount it on the back or front of the trailer. Probably the back since my tongue weight is around 2000lbs.
2008 Blue Streak Metallic Double Cab 4x4 Limited 5.7L
2009 Outback 310BHS Sydney Edition 10,060lbs 35'10"
Prodigy, Retrax, Equal-i-zer, Load Lifter 5000
